Unity Connection 1.2(1) Direct Routing Rule Calling Number does not allow *
Hi All,
I have set up multiple 'Attempt Sign In' and each with a different language and was hoping to use the Calling Number field so that 46* identifies the caller (via external number mask from the HL of course) as Swedish Caller they get 'Please Enter Your Password in Swedish' but the Calling Number field will not allow a '*' I get an error saying only 1-9 characters are allowed.
Were as the help file says :
Calling Number Enter the phone number to have the rule apply to a phone number from which calls originate. To have the rule apply to all originating phone numbers, enter * or leave the field blank. The * is a wildcard and can be used alone or with other numbers (for example, enter 212* to control routing of all calls from that area code). When a call matches all settings for the rule, the call is routed as specified in Send Call To. Note Your integration may not support this option.
So is the * allowed ? If not what integration allows it ?
Best regards,
Phillip
1 REPLY
Re: Unity Connection 1.2(1) Direct Routing Rule Calling Number d
No problem I found :
CSCsg04190: Cannot use asterisk for miscellaneous digit in Routing Rule DN's
Fixed in ES11
115
