Unity Connection 1.2 - import help
Is there any 'import tool' in Unity Connection that will allow me to bulk update the E-MAIL Address field for SMTP for all the users?
Would be greatly appreciated if anyone can shed some lights on this.
Kind Regards,
Hunt
Re: Unity Connection 1.2 - import help
The Bulk Administration Manager which you'll find in the Tools Depot can update the EmailAddress field using CSV input - check out the help for the tool, there's a section titled "Constructing the Input CSV files" that lists all the possible column names you can update using an input file.
hi lindborg,
I tried that but even the import was a success, it didn't import any of the SMTP email address.
As an additional trial, I 'manually' update one user with Email address and did a Bulk Admin Mgr export, but even then the exported CSV file does not contain the email addresses i typed in for the user anywhere.
Have you had any success with CSV for email before??
119
