Community Member
Unity Connection 2.0 Direct Routing Rule Problem
I'm using :Cisco Unity Connection Version 2.0.1.2000-337
After deleting a Direct Routing Rule in the Direct Routing Rules page now is not possible to make any changes because all buttons disappeared. I made a restart to the server but still the same situation. Anybody has a clue of what to do?
Re: Unity Connection 2.0 Direct Routing Rule Problem
what do you mean all buttons disappeared??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
I mean that there is no "add new" button or any other button.
Is only the "Copyright © 1999 - 2006 Cisco Systems, Inc." with the rest that is on the about page.
128
