Unity Connection 2.1 - codec question
Q1) How to set the Unity Connection default codec to g729? I cannot setup while installation which does in Unity. is that mean both codecs are installed automatically for system prompts and can use as per port group 'code advertising' setup?
Q2) How to calculate the Unity Connection mailbox size for g711 and g729? I want to calculate the total mailbox size for all users per codec type.
Thanks in advance,
1 ACCEPTED SOLUTION
Re: Unity Connection 2.1 - codec question
a quick search on CCO can provide many answers:
Changing the Audio Format for System Prompts (G.711 or G.729a)
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/1x/administration/guide/acm110.html#wp1040912
Changing the Audio Format of Recordings, Prompts, and Media Streams
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/1x/administration/guide/acm120.html
Audio Codecs
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/design/guide/5xcudg030.html#wpxref40974
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Audio Codecs
javalenc
java
131
