05-22-2008 05:44 AM - edited 03-18-2019 08:59 PM
Two questions chaps.
1st - Can Unity Connection v2x run with a Call Manager 4.1.3 environment?
2nd - Can any of you point me in the right direction of any decent unity connection installation guides?
As always your help is greatly appreciated.
Rod
Solved! Go to Solution.
05-22-2008 06:23 AM
All the Cisco docs for CUC (including 2.1) can be found here:
http://www.cisco.com/en/US/products/ps6509/tsd_products_support_series_home.html
The oldest CM version supported according to the compatibility matrix found at the site above is 4.2
05-22-2008 06:23 AM
05-22-2008 06:24 AM
Thanks Jeff.
05-22-2008 06:26 AM
Hi Rod,
Sadly 4.1(3) is not supported.
Supported Version Combinations for Cisco Unity Connection 2.x and Cisco Unified Communications Manager
Cisco Unified Communications Manager 6.1(x), 6.0(x), 5.1(x), 5.0(x), 4.3(x), 4.2(x)
From this good doc;
SCCP Compatibility Matrix: Cisco Unity Connection, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Installation Guide for Cisco Unity Connection Release 2.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/installation/guide/2xcucigx.html
Hope this helps!
Rob
Edit: Beaten to the punch by the Unity guru Jeff ;-)
05-22-2008 06:30 AM
Thanks Rob, I was expecting the first reponse from you.. but well done to jeff.
3 points for giving me a direct link to the uc install pdf.
Thanks to all
Rod
