09-08-2011 06:28 AM - edited 03-19-2019 03:34 AM
I have a physical server on CUC Version 7.1.5.30000-117 I take a DR Backup 100% fine.
I have built a new VM and installed CUC Version 7.1.5.30000-117, it has the same name and IP address,
when I attempt to restore the DR I get an error on
Connection_Database Failure at 60%
and
Connectio_Message_Unitymbxdb1at 5%
The error log file says
"Physical restore failed - could not fork server copnnection, SQLCODE -25596"
and
"Phython C API version mismatch for module iproduct: This python has API version 1013, module iproduct has version 1012"
I have attempted the restore twice with identical results.
Any ideas ??
James
Solved! Go to Solution.
10-14-2011 03:47 AM
Prehaps this is a license issue.
I am attempting to restore to a box with the demo license installed.
Can you let me know how you get on ??
10-17-2011 01:40 AM
I got a resolution to this issue - the DNS servers MUST be available and reachable for the restore to work.
It was as simple as that.
02-06-2013 03:39 AM
Just had the above issue.
I was using dummy DNS values just to get running, after putting in a real server that had an entry for unity it worked.
THANKS
Rob
08-18-2014 06:42 AM
Dear Keanej,
I'm migrating CUC version 8.0.4 from MCS server to UCS server. Since the MCS server is in the site which is up and running, we took a demo MCS server in our lab which is satisfying all hardware pre-requisites and installed CUC version 8.0.4. But when restoring the backup which we took from the site, it gets failed on this component CONNECTION_MESSAGES_UNITYMBXDB1. I think its related to the issue you faced. Please mention how you resolved.
Nikitha George
