Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unity Connection 7 SIP Not Transferring
I have Unity Connection 7 with a SIP integration to call manager and everything on my network configured to use G729. Unity Connection accepts calls and works fine for voice mail, but when it tries to transfer to an extension from the directory handler, it says "please wait while I transfer your call" and then it immediately plays the subscriber's mailbox greeting. I've checked and all of my subscribers are set to "Transfer to extension" and the transfer type is "transfer to switch". any assistance would be greatly appreciated.
Re: Unity Connection 7 SIP Not Transferring
Robert, did you get this fixed - i have a similar issue?
I did. As I recall I had to check the require MTP box on the SIP trunk configuration in CUCM and reset the trunk.
408
