Unity Connection 8.5 Cluster Problem
I have upgraded to 8.5.1.13900-5 but I am having a problem with the cluster.
They cant see each other.
When I do a
Show CUC cluster status
i publisher I see
Server               State          Internal State                             Reason
MYSERVERA - Primary - Sec Act Primary Disconnected  - Normal
MYSERVERB - Disconnected      Unknown                         Unknown
On subscriber I see
MYSERVERA - Disconnected      Unknown                         Unknown
MYSERVERB - Primary - Sec Act Primary Disconnected  - Normal
I have tried to change the security password
set password user security  - on both boxes.
FYI - On the web gui - under cluster management - both see each other as 'unreachable'
Any other advice ??
Re: Unity Connection 8.5 Cluster Problem
Gee-pers - no one knows cuc ???
Any Cisco people to help out perhaps??
You'll want to get the output of utils cuc dbreplication status and make sure the enterprise replication has an RTMT status of (2) across the board.  If not, it's similar to CUCM and you'll need to possibly rebuild enterprise replication between the two servers first before UC replication will work.  If ER looks good, then you'll likely need a TAC SR to investigate why UC replication may be broken.
Hope that helps,
Brad
It would appear that my enterprise replication is not working due to servers being unreachable
Should I just rebuild the subscriber again ??
What creditentals are used by CUC for replication - is it just the 'security password'
I reset this on both boxes - is there any other creditentals I should check / reset ??
Any help appreciated
James
993
