02-27-2012 08:51 AM - edited 03-19-2019 04:28 AM
I am curious as to whether anyone can confirm or deny that Unity Connection 8.5 Directory Handler can be both voice-enabled and keypad entry simultaneously. I didn't think so, and saw a previous post where someone that they had to be separate, but I see in Cisco Doc
under "Directory Handlers in Cisco Unity Connection 8.x"
Could someone please clarify this for me? Thanks!
Mike.
Solved! Go to Solution.
02-27-2012 01:16 PM
Hi Mike,
Yes, if you create a directory handler that is voice enabled then you have to specify them by name (or use a voice command). If you try a keypad entry then it will say 'invalid entry'.
Let me know if you have any other questions.
Brad
02-27-2012 01:16 PM
Hi Mike,
Brad
02-28-2012 06:33 AM
Brad, Thanks for confirming. I just re-read my doc that I quoted and see where my mis-understanding was: "or enter an extension by SAYING the individual extension"
Thanks.
