Community Member
Unity Connection 9.1 call handlers always transfer calls straight to voicemail
I'm not sure what I have configured wrong but when someone reaches one of our auto attendant call handlers and accesses the dial by name directory it always transfers the call straight to voicemail as opposed to ringing the user's extension. Please advise or let me know if you need more information to assist me.
Hall of Fame Super Red
Hi there,
This is controlled by this user setting;
Transfer Action
Transfer Calls To:
On the User> edit> Transfer rules
You can set this on the User template for future users and use Bulk edit
to change for existing users
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Community Member
I checked this setting on one of the users that I know to be having this problem and the setting of "transfer calls to: extension" is already checked as you are suggesting.
In addition to the configuration Rob mentioned (+5), what usually happens in this scenario is that the transfer from UC's voicemail ports is actually failing to complete, so it rolls back to the greeting of the user - giving you the impression that the configuration isn't working.  Double check your VM ports and their ability to place calls to the phone extensions.
Hope that helps,
Brad
Community Member
ok, we found the solution. The setting of the reroute CSS on the SIP trunk to the Unity Connection server in CUCM was not set correctly. Thanks for the tip anyway.
Hey Brad,
Makes sense that this behavior would manifest itself with the failed
transfer! +5 for adding this great tip
Cheers!
Rob
- The Band
3470
