Unity Connection 9 Auto Attendant Caller Restrictions
I work for a school district.  We have CUCM 9 and CUC 9.  We are looking to set up an AA for one school who receives more calls than they can answer.
My question is this:
Can I restrict the internal extensions callers can dial from the AA to those at the school?  The school has numbers in the range 19XXX.  If possible I don't want to allow parents to call this school's AA and reach extensions at other schools or sites within the district.  The Unity system is of course district wide.
Example:  School with AA is 19XXX.  Dialing any 19XXX will work.  Dialing 24XXX (which is another school not intended for this AA) should fail.
I was looking at directory handlers but that seems to be for dialing by name.  I don't intend to activate that feature.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Scott,
You should be able to leverage the Unity Connection partition &
search space configs to manage how these directory searches work
Managing Partitions and Search Spaces in Cisco Unity Connection 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag235.html
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Re: Unity Connection 9 Auto Attendant Caller Restrictions
Yes, configure the restriction tables as you need.
java
if this helps, please rate
www.cisco.com/go/pdi
But if we later on need to add a second AA for another site, would this idea still work?  I thought restriction tables were system wide, not specific to a particular call handler.
Hi Scott,
Cheers!
Rob
- Bob Marley
393
