Community Member
Unity Connection and SRST
I need to know what my options are with the following scenario...
Two sites: HQ with CM Cluster and a Unity Connection Server, and a remote site with SRST and a separate Unity Connection Server. I want the remote site's Unity connection to register with the SRST gateway in the event of a WAN failure/loss of communication to the CM Cluster at HQ. What options do I have? Do I have to allocate some ports permanently to the SRST gateway and build a separate integration?
1 REPLY
Silver
Re: Unity Connection and SRST
I think following document will help you .
Cisco Unity Connection Installation Guide, Release 1.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/1x/installation/guide/inst.html
124
