Unity Connection Call Handler - Dial DN if no caller Input
I currently have a Call Handler set up that prompts the user with 2 choices that directs them to the relevant DN in Call Manager.  The recording did not say "Or press 4 to return to customer services".
I am looking for a solution so that if the caller does not make any inputs, it dials a number already set up in Call Manager.
I looked to use the send caller to Operator, but this is a global setting, I have other call handlers.
Any idea how I can get it to transfer to another DN if there is no caller input, I just cant see the option ...
Cheers
  • Unified Communications Applications
Bronze
If you will be calling an existing Unity Connection User, you can set the after greetings action to a User with a mailbox (select the attempt transfer option)
That's the only way I can think of right now, but If there's another way, I'm pretty sure someone on here can tell you!
Gareth
Hall of Fame Super Silver
Re: Unity Connection Call Handler - Dial DN if no caller Input
You can define another call handler that transfers the call to desired destination then use this call handler as the destination for the after greeting, and on the greeting check allow transfers to destinations that are not unity call handlers or users, or whatever the checkbox says :-)
Chris
135
