08-17-2012 03:57 AM - edited 03-19-2019 05:23 AM
I'm currently getting an error for some messages when I do a COBRAS Export.
Unity Connection version 7.1.3
At the beginning the IMAP connection is successful.
[Thread 001], [12/08/16 07:57:52], Checking IMAP connectivity capability before starting export.
[Thread 001], [12/08/16 07:57:52], IMAP connection established to target.
But for a lot of messages the export is failing - Any Ideas?
[Thread 013], [12/08/16 08:06:59], (error) fetching email via IMAP. Message index=567, error=ChilkatLog:
FetchSingle:
DllDate: Jan 19 2012
UnlockPrefix: LNDBRGIMAPMAILQ
Username: YYYYYYY:XXXXXXX
Architecture: Little Endian; 32-bit
Language: .NET 4.0
Failed.
--FetchSingle
--ChilkatLog
Is this happening for secure messages? Maybe the export is not allowed? Any settings not allowing the export of this messages?
How can i check if I have secure messages on that server?
I did the Export for another server as well. No errors is this situation.
Paul
Solved! Go to Solution.
08-17-2012 06:07 AM
I don’t think it’s likely that secure messages would be causing IMAP failures like that on individual messages over normal messages, though – COBRAS establishes a secure SSH connection via IMAP when attaching for the super-user access model used for Connection’s IMAP backup and restore mechanism – once established all messages of any type are available – there’s no difference in secure vs. non secure at that level other than the flag in the header. You wouldn’t be more or less likely to get individual message failures based on their secure flag or not.
More likely you have some damage on the Connection side (i.e. file system/db error – I see this now and again with sites that take a power hit or the like and then decide it’d be a good idea to get a backup for instance) – there’s no way to tell from the client side much in the way of details, that error gets issued from the server side – you’d need to set some diags on the Connection server side to see what it’s coughing up.
It could be that Connection is having a particular problem with secure messages but I’d be very surprised if that were the case.
08-17-2012 05:57 AM
Hi Paul,
It probably is secure messages that is tripping this up
COBRAS does support exporting and importing secure messages into Connection 7.x and later installations and exporting secure messages from Unity 5.x and later installations. It does not support importing secure messages into any version of Unity or to or from Connection 1.x.
COBRAS employs a highly secure AES 128 bit encryption algorithm to encrypt secure messages in the backup database. There are also additional checks required on export to see if each individual attachment (for instance a multiple part message) is secure – if it is the entire message needs to be encrypted. This will add some overhead to the export process – only select the option to include secure messages if you really need them.
There are a few important notes to keep in mind about secure messaging support:
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
08-17-2012 06:07 AM
12-13-2012 11:32 AM
Just a short update on this.
We opened a SR to clarify this.
Turns out that these messages were already damaged and not available anymore in CUC.
So its like Jeff said a faulty CUC.
Paul
08-17-2012 06:22 AM
Hey Jeff,
Thanks for weighing in here. To get feedback right from the "top" engineer
and designer of these products is invaluable to say the least!
I'm not sure what we'd all do without this great suite of tools
Cheers!
Rob
06-20-2013 02:18 PM
hi,
has anyone ever installed the unity connection 7.x import tool on a unity 7.02 server ? it requires .net4 - will that affect the Unity server?
