Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unity connection default settings
In trying to get other things operation on Unity connection I have managed to make it not work correctly.
When I go into the system it asks for an id and pin, before it would just ask for the pin and then you would hit * if you wanted a different number then your extention.
I am certain it is an easy fix, but can not find what I did to make this change. It also appears that if you hit # it doesn't redirect it either. It just hangs up on the call.
1 REPLY
Re: Unity connection default settings
Hi -
The places I would check first are:
- On your own account, caller input keys. Also check to see what conversation you are using.
- System Call Handlers - Opening Greeting - caller input keys.
- In CallManager, does your DN still have the right voicemail profile selected? It sounds like you have lost your easy message access to voicemail if you get prompted for userid and pin when you press the Messages key.
Ginger
153
