Community Member
Unity Connection installation question
Folks
I have Cisco unity Connection Application Software Disc Set that cisco distribute for testing purposes.
This kit has only the software and don't have the Windows 2003 CD shipped by Cisco.
I will use a Windows 2003 retail version but I need to know in advance how the cisco windows 2003 CD partitions the hard disk. How many partions needs to be created?
Somebody that have installed it on a 7825 perhaps may take a look into his Server and comeback with the information of how it is partitioned.
I know it might fail since it is not the cisco customized version of W2003 but I want to give it a try.
TIA, JB
Hall of Fame Super Silver
Re: Unity Connection installation question
I don't remember how it's partitioned but you dont have to partition it the same way, you can actually install CUC on any win2003 server with the following switch:
setup.exe /NOPCD
I've done it in the lab and worked great.
HTH,
Chris
Community Member
thanks for replying Chris
Can you please clarify your answer?
Does it mean I can work with only 1 partition and then when installing the cisco connection, I should run the setup with the /NOPCD switch?
Regards, Jorge
115
