09-11-2014 12:49 AM - edited 03-19-2019 08:36 AM
Quick question:
Is it possible to have sub-menu's in CUC IVR?
press 1 for department 1, then new menu: press 1 for sales. 2 for technical, 3 for support
JH
Solved! Go to Solution.
09-11-2014 03:20 AM
yeah. you can do that. go to edit > caller input and configure appropriate call action to send the call to another call handler.
09-11-2014 01:03 AM
You can do this by using Call HAndlers in unity connection.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsagx/9xcucsag040.html
regds,
aman
09-11-2014 01:22 AM
I have made IVR's on Unity and Unity connection, but only one level.
Can I create sub menu's, one call handler point to another call handler.
On UCCX and unity express it is very easy to create submenu
JH
09-11-2014 03:20 AM
09-11-2014 03:45 AM
Thank you very much!
