Community Member
Unity Connection Locale for 8.6(2a)SU3
Does someone knows when the new Locales (besides JP) are coming out?
Thanks in advance
Silver
Hello UC Support,
Basically you can use SU 1 locales and they should work.
-Torreto en Bicicleta
Community Member
Thanks David,
I was aware that locale uc-locale-xx_XX-8.6.2.1-25.cop.sgn are compatible with 8.6(2a)SU2. Good to know that SU3 is also compatible.
One more thing, could you update the following link with the appropiate info.
https://supportforums.cisco.com/docs/DOC-29778
Silver
Hi UC Support,
I would be more than glad to modify it but unfortunately this document was outlined by A.M Mahesh Babu, however i will post a comment on it in case he stops by and updates the revision.
-Toreto on bycicle
266
