Bronze
Unity Connection multi-cluster LDAP integration
Question...I'm looking to do two clusters of Unity Connection which will both point to the same AD for their LDAP integration...the manual says you need to use filters so the same mailbox isn't created on two servers (or clusters).  If I'm well under 60k users, would it be a problem to just point to the root of the customer AD for each server/cluster, but only actually import users on one server or the other as subscribers?  We are gradually migrating to the Cisco UC, so we wouldn't be importing massive numbers at a time.
  • Unified Communications Applications
Everyone's tags (3)
1 REPLY
Re: Unity Connection multi-cluster LDAP integration
To be as concise as possible, the recommendations for LDAP integration are documented that way for good reason.  You should stick with best practices when building and populating the CUC clusters.
Hailey
Please rate helpful posts!
383
