Unity Connection MWI not enabling or disabling.
I'm wondering if there is someway to debug why the MWI's are not turning on when a message is left?  I can call the MWI on/off extensions from the phone directly, but when a message is left they do not turn on.  I have gone through the documentation and I just cannot find any setting that i'm missing for this to work.
I have the MWI's set in CUCM, it looks like the user has an MWI-1 set under message waiting indicators, and everything with the port group seems fine.
CUCM 8.0.3.20000-2
Unity Connection 8.0.3.20000-18
Any thoughts?
Dan.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Unity Connection MWI not enabling or disabling.
Are you performing a SCCP or SIP integration?
If SCCP:
  • does the CSS of the voicemail ports include the partition the MWI numbers are in?
  • does the CSS of the MWI numbers include the partition that the user DNs are in?
If SIP:
  • does the SIP Trunk CSS include the partition that the user DNs are in?
  • is the SIP Trunk Security Profile assigned to the SIP Trunk set to allow out-of-dialog REFER, unsolicited NOTIFY, and the REPLACES header?
VIP Super Bronze
If SCCP:
If SIP:
Ah, so simple.  SCCP, and yes the partition was not in the CSS.
Dan.
853
