Unity Connection MWI Problems
Hi, We are running Unity Connection 2.0.1.2000-337 for about 3 months now. Since yesterday, users are reporting that their MWI light is on but when they go into their VoiceMail, they have no messages. But MWI light stays on.
Anyone have some ideas?
Thnx
Re: Unity Connection MWI Problems
go into the integration page and do a MWI refresh to see if that helps.
is this affecting all users or just some of them?
java
if this helps, please rate
www.cisco.com/go/pdi
I have this issue with just one issue out of 50+
MWI is on but no messages, I deleted the user in Unity and recreated, the problem still persists.
did you manage to solve this issue, I cannot see that the fix is to synchronise MWi on a daily basis?
Are the numbers for MWI by chance reversed in unity or CM
ie
5000 is MWI on in call manager
5001 is MWI off in call manager
5001 is MWI on unity
5000 is MWI on Unity
I have checked as I was really hoping this might be the problem...no in both Unity and CCM we have 7710 on 7709 off.
I have a customer on 2.1.0.9901-362 and they are reporting the same issue. Every other day we have to refresh the MWI.
A manual resync kinda sorted out my problem, but shortly after that we also moved the kit to another building so it could have even been the restart that sorted the problem.
I have to carry out a manual resynch on a daily basis, I have educated one of the users to dial the MWI off number.
There has to be a reason why Unity alerts a phone with MWI on when there is no message, this must happen over night after some kind of automated process on Unity.
If it keeps happening your best bet will be to contact TAC.
1312
