Hi Ken!
Seems you are hitting a known bug: CSCsx42105
Reports: Extensions longer than 5 digits are truncated
When running reports in UC 7.0(1), user's extension longer than 5 digits are truncated.
Symptom:
When run in .csv or web output, extensions longer than 5 digits are truncated.
Conditions:
UC 7.0(1)
Workaround:
None.
This is fixed in 7.0(1) and 7.0(2) so you'll need to upgrade to 7.0 and open a case with TAC to get an ES with the fix.
Hope this helps!
Teresa.
Tere.
If you find this post helpful, please rate! :)
