Unity Connection using COBRAS to convert to LDAP
Can Cobras be used to import voicemail messages when converting Unity Connection subscriber accounts to be imported via AD/LDAP, assuming the subscribers extensions remains the same.
1 REPLY
Re: Unity Connection using COBRAS to convert to LDAP
The alias and extension would need to match (you can change these in the backup using the COBRAS Data viewer utility if necessary). As long as the imported users are created first and then you do the COBRAS import it should work fine. The other way around does not work - you can't convert a pre created local user into an LDAP imported user easily...
523
