Unity Express not detecting call termination with FXO port
I have a CME box with Unity Express and an FXO port connected to a standard PSTN line.
When I call in from an external source, it connects to the Unity Express fine and takes a message.
When you hang up, Unity Express doesn't detect this properly and records an egaged tone until it times out. The PSTN line is tied up while this happens.
Any ideas?
Mark
voice-port 0/2/0
connection plar opx 123456
station-id name PSTN_Connection
station-id number 123456
caller-id enable
1 ACCEPTED SOLUTION
Re: Unity Express not detecting call termination with FXO port
That has to do with your FXO connection, not unity express. You can see this with a 'debug ccsip message'. Unity express will never get a SIP BYE message when the PSTN side is hung up. Take a look at:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121limit/121x/121xm/121xm_5/dt_dscon.htm
and
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
and
Hi marschne,
That seems to have done the trick. It does still record a second of engaged tone, but its a lot better now,
Many thanks,
Mark
voice-port 0/2/0
supervisory disconnect dualtone mid-call
cptone AU
timeouts wait-release 1
impedance complex1
caller-id enable
Blue
please see the following link for the Understanding FXO Disconnect Problem:
if still an issue, post your config and we can verify if any other problems possibly.
484
