Unity Failover SQL issues
When installing SQL on a Unity failover server, does the Unity setup app cripple the admin tools? SQL is running fine, but I can't get enterprise manager to work, and the "service manager" app starts then immediately stops. I can connect to SQL from a separate box using enterprise manager, but it seems like some files associated with EM are missing on the failover("SQL Server EEnterprise Manager.msc" for instance.)
Silver
Re: Unity Failover SQL issues
What part of this document did you think would apply? SQL is installed, SQL SP3a is installed. I actually discovered the problem trying to run Cisco's MS patch tool, as it said it did not detect a SQL server, even though SQL is running. I can get to SQL via enterprise manager from a separate server(adding a registration for the unity failover server).
104
