Unity Problems after enabling SSL
I just enabled SSL (as detailed in the docs) manually after installing Unity 4.1(1) but I am still having 2 problems:
1.) When Blackberry Mobile Access clients use the URL to play their voicemail, the next page (that allows you to change the number or whatever) does not load. There used to be a page that would load that would indicate the number that unity outcalled with a "Change" button.
2.) Surfing the SA pages using SSL we occasionally get an error out of IE saying that the page contains both secure and insecure items. This is a mild annoyance (since we need to click yes), but I would love to know if this is expected or it is actually an error?
Many thanks in advance!!
-Gordon
1 REPLY
Re: Unity Problems after enabling SSL
Hi Gordon -
For the IE error, from your workstation, go to Internet Options / Security / Custom Level / Display Mixed Content = Enable
Regarding the Blackberry, did you add the certificate to the trusted root store on the BlackBerry server? Your users may not be getting the prompt that allows them to add Unity as a trusted server.
Ginger
105
