Unity Tray Icon Stuck Pointing Up
Unity 4.05, seems to be working, event viewer clean. Tray icon stuck pointing up.
Any suggestions? This is a new install, VM only, member server in domain, CCM integrated. Ports registered and Unity is answering.
Re: Unity Tray Icon Stuck Pointing Up
Update: Tray icon doesn't change when you stop or start Unity
Once the tray icon looses it's connection to the running status of Unity, you have to unload it and reload it - this happens now and again. Just right click on it and select "exit" to unload it and then run "CsTrayStatus.exe" from the \commserver\ installation directory. It will reestablish the connection to the gateway and show the proper status of Unity again.
282
