01-09-2008 02:10 AM - edited 03-18-2019 08:18 PM
I have problem with unity recently some phones where moved from one location to another. So the partition and CSS where changed accordingly. The phones ring fine apart from when they are being forwarded to VM then it rings engaged although the old number forwards them fine. The new number is 01606 275303 and the old number was 01270 275303.
Any help appreciated.
Kev
01-09-2008 05:44 AM
Hi Kev,
Sounds like it may be a CSS issue on the Call Forward CSS. Can these phones call the Unity Pilot #? If so, maybe you could try applying the same CSS that is used for the Line or Device (whichever you are using) to the Call Forward CSS.
Hope this helps!
Rob
02-21-2008 07:20 AM
Rob,
It would appear that the second call that is passed to Unity is ringing engaged. Any idea what would cause this?
Kev
