UnityConnection 8.6 VM issue + DB replication issue
We recent just rebuild and restore UnityConnection  Publisher completely. But issue start occurs - when call hit VM system,  user either hear dead air or disconnected straight way.
We stopped all the ports on publisher to take call, then call him VM with no issue. Any idea ?
Furthermore, we suspected that db replication status on publisher shows below:
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2013-08-21-21-06
     Replication status command COMPLETED 541 tables checked out of 541
     No Errors or Mismatches found.
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_08_21_21_06_57.out' to see the details
DB Version: ccm8_6_2_21900_5
Number of replicated tables: 541
Cluster Detailed View from PUB (2 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
POL-CUC1        10.10.35.36     0.055   Yes     Connected       0       match   Yes     (2) PUB Setup Completed
PIB-CUC1        10.2.35.36      1.00    Yes     Connected       0       match   Yes     (2) Not Setup
As you can see, value are 2 but PIB-CUC1 show Not Setup.
Same command on subscriber show below
Cluster Replication State: Only available on the PUB
Cluster Detailed View from SUB (2 Servers):
POL-CUC1        10.10.35.36     0.997   Yes     Connected       0       match   Yes     (2)
PIB-CUC1        10.2.35.36      0.049   Yes     Connected       0       match   Yes     (2)
Not sure whether db replication looks fine or not?
Whether this db replication cause VM stop working on publisher?
Fei
Everyone's tags (1)
1 ACCEPTED SOLUTION
Silver
Hello Fei,
Based on the fact that you had to rebuilt the Publisher server i was wondering if you ran the folllowing command:
This command creates a clsuter relationship with the publisher server in a Connection cluster after the server was replaced or after Connection was reinstalled on the publisher server. The command overwrites all data on the publisher server with data from the subscriber server and initializes data replication between the servers.
COMMAND SYNTAX
utils cuc cluster renegotiate
USAGE GUIDELINES
Run this command on the subscriber server in a Connection cluster to set up a trust with a publisher server that has been replaced or on which Connection has been reinstalled.
This command can be referenced here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html
If the command above was used then you might want to consider:
Running  'utils dbreplication stop all' to stop the replication and 'utils dbreplication reset all' to tear down and rebuilt replication. The replication should be restored to normal after this.
For the calls being dropped it would be interesting if you could verify whether the ports registered on the CUCM were flapping.
Best Regards,
David Rojas Peck.
Silver
Hello Fei,
COMMAND SYNTAX
USAGE GUIDELINES
Best Regards,
David Rojas Peck.
Hi David
Appreciate your response.
We did use command utils cuc cluster renegotiate on subscriber after finish rebuild publisher.
Also issue command utils dbreplication stop on sub and pub in order, then utils dbreplication reset all on pub and wait 30 mins and dbreplication status all good.
Fei
483
СоздатьДля создания публикации, пожалуйста в систему
