vCenter Required for R210-BUN-1 Hardware ?
Please Check the BoM .  Do we need to add vCenter for this BoM or It just work fine with VMware client which is free ?
For Tested Reference Configuration TRC , It works fine .But as this is not TRC , Please Verify.
Part Number
Service Dur.
Quantity
11.0
VMW-VS5-EP-3A=
CON-ISV1-VS5ENTP3A
36.00
R210-BUN-1
CON-UCS1-R210BN1W
12.00
UCS-MR-1X041RX-A
R210-ODVDRW
R210-SASXPAND
R2X0-PSU2-650W-SB
R2XX-G31032RAIL
R2XX-PL003
A01-X0105
R210-BHTS1
R200-PCIBLKF1
SASCBLSHORT-003
UCS-MR-1X041RX-A
A03-D300GA2
6
12.13
N20-BBLKD
CAB-9K10A-UK
R2X0-PSU2-650W-SB
Power Cord, 250VAC 10A BS1363 Plug (13 A fuse), UK
650W power supply, w/added 5A Standby for UCS C200 or C210
CPU heat sink for UCS C210 M1 Rack Server
PCIe Full Height blanking panel for UCS C-Series Rack Server
1 Short SAS Cable for UCS C210 Server ( for SAS Expander)
4GB DDR3-1333-MHz RDIMM/PC3-10600/1R/1.35v
300GB 6Gb SAS 10K RPM SFF HDD/hot plug/drive sled mounted
UCS 2.5 inch HDD blanking panel
DVD-RW Drive for UCS C210 M1 Rack Servers
SAS Pass-Thru Expander (srvr requiring > 8 HDDs) - C210
Rail Kit for UCS C200, C210 Rack Servers (23.5 to 36)
LSI 6G MegaRAID 9261-8i card (RAID 0,1,5,6,10,60) - 512WC
2.66GHz Xeon X5650 95W CPU/12MB cache/DDR3 1333MHz
VMware vSphere 5 Enterprise Plus (1 CPU),3yr Support Require
ISV 24X7 VMware vSphere EnterprisePLUS, List Price is ANNUAL
UCS C210 M2 Svr, 2x X5650, 2x4GB, SAS Expand, 1PS
UC SUPPORT 8X5XNBD UCS C210 M2 Rack Server
Part Description#
Part Number
Service Dur.
Quantity
11.0
VMW-VS5-EP-3A=
CON-ISV1-VS5ENTP3A
36.00
R210-BUN-1
CON-UCS1-R210BN1W
12.00
UCS-MR-1X041RX-A
R210-ODVDRW
R210-SASXPAND
R2X0-PSU2-650W-SB
R2XX-G31032RAIL
R2XX-PL003
A01-X0105
R210-BHTS1
R200-PCIBLKF1
SASCBLSHORT-003
UCS-MR-1X041RX-A
A03-D300GA2
6
12.13
N20-BBLKD
CAB-9K10A-UK
R2X0-PSU2-650W-SB
Part Description
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You do not need vCenter as it is optional components. You can use free vSphere client, but some features are only available from vCenter, vCenter also allows you to manage all servers from central place.
HTH,
Chris
1 REPLY
HTH,
Chris
592
