Verify deployed IP phone firmware
BEN ROBINSON
Hello!
We have a 1200 user CUCM deployment and have noticed that some IP phones are using an old firmware while others were upgraded. We tried running a report under Unified Reporting > System Reports > Unifed CM Phones with mismatched load, but nothing is showing up and we know they are out there. Anyone have a way to check this otherwise?
Phones have web access enabled.
Please advise. Thanks!
Ben
Aaron Harrison
You can use the inventory app from here: www.ipcommute.co.uk
It will go out to each phone and retrieve the running firmware version from the phone's web server.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks! I'll give it a go!
