VIC-4FXS/DID with analog phones installed
l configured the router 2801 with the VIC-4FXS/DID on slot 0, but the two analog phone that l attached to it did not ring nor did it bring a dailled tone. The CUCM 8.0(2) is working with the 3 IP Phones that was installed into the network. The 3 IP Phones was registed automatically when it was plug into the socket and they calling each other which was supplied by the CUCM. I am woundering why the analog phones that l plug into the vic-4FXS/DID it did not ring. The devices that l used were Cisco router 2801, switch 2950, a stand alone computer for the CUCM, 3 IP Phones and two analog phones.
3 ACCEPTED SOLUTIONS
VIP Super Bronze
Well for starters I don't see the voice-ports in the running configuration. Does a 'show inventory' show the card installed at all and in subslot 0?
Please remember to rate helpful responses and identify helpful or
VIP Super Bronze
You're totally fine to configure the VIC in CUCM since this is a MGCP gateway with the ccm-manager config comman present. CUCM will push the appropriate configuration to the router.
What stands out at me from your running config is the total absense of the voice-ports. These should appear automatically if the VIC card is online; regardless of your CUCM configuration. Their absense suggests that the card is either missing from IOS's perspective (e.g. defective); or, you have insufficient DSPs to perform voice termination for the ports. Get the voice-ports 0/0/0-3 to show up in the configuration before turning your attention to CUCM.
VIP Super Bronze
The show inventory indicates that your router does not have any DSPs (PVDM2-XX) and therefor will never enable the VIC card. You need to order DSPs and install them in the PVDM2 slots on the motherboard before continuing. The DSP Calculator will help you understand what part numbers you need.
VIP Super Bronze
Hi Jonathan,
I did not configure the voice port on the gateway but l enabled it on the CUCM it's self. Do l need to configure voice port on the router which is the gateway too? Because l thought everything must be centralized on the CUCM. I will do that and l will get back in touch with you Jonathan. And l will like to ask you what do you do you think with my configuration. Anymore config should l add on it pls.
Thanks for your help
Jonathan
VIP Super Bronze
Hi Jonathan,
U are a star. The light lit up when l plugged the card into the router 2801 and l think that is an indication that is working if am right. Like you said earlier, l will do show voice-ports 0/0/0-3 config to see if the port will show up as you said. I will let you see the config when it done.
Thanks a million
Ojay
Hi Jonathan,
am having a problem of how to configure the voice port. I try to use the voice port config but it is rejecting it. I don't mind if you can put a config which l can use for this port pls.
Router#sh inventory
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801         , VID: V04 , SN: FCZ1218949N
NAME: "VIC 0", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC1233057M
NAME: "WIC/VIC/HWIC 1", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 36399297
NAME: "WIC/VIC 2", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 36242801
NAME: "WIC/VIC/HWIC 3", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 25666361
Router#sh dsp all
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
Total number of active session(s) 0, and connection(s) 0
Total number of DSPFARM DSP channel(s) 0
Router#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  administratively down down
Serial0/1/0                unassigned      YES unset  administratively down down
Serial0/2/0                unassigned      YES unset  administratively down down
Serial0/3/0                unassigned      YES unset  administratively down down
Router#
Router#
Router#
Router#sh voi
Router#sh voice po
Router#sh voice port summ
Router#sh voice port summary
                                          IN       OUT
PORT           CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
PWR FAILOVER PORT        PSTN FAILOVER PORT
Router#sh diag
Slot 0:
        C2801 2FE 4SLOT Mainboard Port adapter, 12 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Chassis MAC Address      : 001f.ca07.a658
        MAC Address block size   : 34
        PCB Serial Number        : FOC1213159H
        Hardware Revision        : 7.0
        Part Number              : 73-8190-07
        Board Revision           : C0
        Top Assy. Part Number    : 800-23435-05
        Deviation Number         : 0
        Fab Version              : 04
        CLEI Code                : IPM7V00CRA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : CISCO2801
        Version Identifier       : V04
        Processor type           : 86
        Chassis Serial Number    : FCZ1218949N
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C3 06 00 1F CA 07 A6 58 43 00 22 C1 8B 46
          0x10: 4F 43 31 32 31 33 31 35 39 48 40 04 1C 41 07 00
          0x20: 82 49 1F FE 07 42 43 30 C0 46 03 20 00 5B 8B 05
          0x30: 88 00 00 00 00 02 04 C6 8A 49 50 4D 37 56 30 30
          0x40: 43 52 41 03 00 81 00 00 00 00 04 00 CB 89 43 49
          0x50: 53 43 4F 32 38 30 31 89 56 30 34 20 D9 02 C1 40
          0x60: 09 86 C2 8B 46 43 5A 31 32 31 38 39 34 39 4E FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        VIC Slot 0:
        FXS DID Voice daughter card (4 port)
        Hardware Revision        : 3.1
        Part Number              : 73-6918-02
        Board Revision           : F0
        Fab Version              : 02
        PCB Serial Number        : FOC1233057M
        RMA History              : 00
        Top Assy. Part Number    : 800-17016-02
        Connector Type           : 01
        CLEI Code                : IP9IABYCAA
        Product (FRU) Number     : VIC-4FXS/DID=
          0x00: 04 FF 40 00 3A 41 03 01 82 49 1B 06 02 42 46 30
          0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 32 33 33
          0x20: 30 35 37 4D 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 42 78 02 05 01 C6 8A 49 50 39 49 41 42 59
          0x40: 43 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 1:
        Serial 1T WAN daughter card
        Hardware revision 1.0           Board revision D0
        Serial number     36399297      Part number    800-01514-02
        FRU Part Number     WIC-1T=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
          0x20: 01 02 01 00 02 2B 68 C1 50 05 EA 02 00 00 00 00
          0x30: 68 00 00 00 08 03 28 01 FF FF FF FF FF FF FF FF
        WIC/VIC Slot 2:
        Serial number     36242801      Part number    800-01514-02
          0x20: 01 02 01 00 02 29 05 71 50 05 EA 02 00 00 00 00
          0x30: 68 00 00 00 08 01 10 01 FF FF FF FF FF FF FF FF
        WIC/VIC/HWIC Slot 3:
        Hardware revision 1.0           Board revision L0
        Serial number     25666361      Part number    800-01514-01
          0x20: 01 02 01 00 01 87 A3 39 50 05 EA 01 00 00 00 00
          0x30: A8 00 00 00 01 09 01 01 FF FF FF FF FF FF FF FF
Router#sh flash
-#- --length-- -----date/time------ path
1     43251680 Feb 23 1907 20:15:44 +00:00 c2801-advipservicesk9-mz.124-15.T14.bin
2         4668 Oct 7 2011 11:12:30 +00:00 admin_user.html
3       667582 Oct 7 2011 11:13:58 +00:00 admin_user.js
4         1602 Oct 7 2011 11:14:18 +00:00 CiscoLogo.gif
5          639 Oct 7 2011 11:14:40 +00:00 CME_GUI_README.TXT
6       331483 Oct 7 2011 11:15:02 +00:00 CP7902080001SCCP051117A.sbin
7       338840 Oct 7 2011 11:15:24 +00:00 CP7905080001SCCP051117A.sbin
8       338424 Oct 7 2011 11:15:42 +00:00 CP7905080001SCCP051117A.zup
9       340631 Oct 7 2011 11:16:04 +00:00 CP7912080001SCCP051117A.sbin
10         953 Oct 7 2011 11:16:24 +00:00 Delete.gif
11         497 Oct 7 2011 11:16:54 +00:00 DistinctiveRingList.xml
12       16948 Oct 7 2011 11:17:14 +00:00 dom.js
13         864 Oct 7 2011 11:17:34 +00:00 downarrow.gif
14        6315 Oct 7 2011 11:17:50 +00:00 ephone_admin.html
15        4658 Oct 7 2011 11:18:06 +00:00 logohome.gif
16        3831 Oct 7 2011 11:18:24 +00:00 normal_user.html
17       81600 Oct 7 2011 11:18:40 +00:00 normal_user.js
18      129476 Oct 7 2011 11:19:02 +00:00 P0030702T023.bin
19         459 Oct 7 2011 11:19:18 +00:00 P0030702T023.loads
20      685334 Oct 7 2011 11:19:46 +00:00 P0030702T023.sb2
21      129880 Oct 7 2011 11:20:04 +00:00 P0030702T023.sbn
22      349794 Oct 7 2011 11:20:22 +00:00 P00405000700.bin
23      350198 Oct 7 2011 11:20:38 +00:00 P00405000700.sbn
24        1347 Oct 7 2011 11:20:54 +00:00 Plus.gif
25        4000 Oct 7 2011 11:21:08 +00:00 Ring1.raw
26        4000 Oct 7 2011 11:21:24 +00:00 Ring2.raw
27        4000 Oct 7 2011 11:21:40 +00:00 Ring3.raw
28        4000 Oct 7 2011 11:21:56 +00:00 Ring4.raw
29        4000 Oct 7 2011 11:22:22 +00:00 Ring5.raw
30         497 Oct 7 2011 11:22:36 +00:00 RingList.xml
31         843 Oct 7 2011 11:22:54 +00:00 sxiconad.gif
32         174 Oct 7 2011 11:23:08 +00:00 Tab.gif
33        2451 Oct 7 2011 11:23:22 +00:00 telephony_service.html
34         870 Oct 7 2011 11:23:38 +00:00 uparrow.gif
35        3493 Oct 7 2011 11:23:54 +00:00 xml.template
36       10230 Oct 7 2011 11:24:12 +00:00 xml-test.html
16863232 bytes available (47149056 bytes used)
Router#sh run
*Nov 30 07:19:52.139: %SYS-5-CONFIG_I: Configured from console by console
Building configuration...
Current configuration : 923 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
voice-card 0
Router(config)#voi?
voice  voice-card  voip-incoming
VIP Super Bronze
Can l connect the AIM-CUE which is inside the 2801 with CUCM the same way that l will connect to the CME. I have a computer which l dedicate for my callmanager 8.0 and l have cisco 2801 which l want to install the AIM-CUE into for my viocemail. The configuration that l have is for the CME, l need the setup for the CUCM for the AIM-CUE for the 2801 which l want to setup. Any advice wher l can find the configuration for the setup pls.
619
