Community Member
Web dialer with Extension Mobility
Hello, I have configured all users with Extension mobilitty each one have a device profile, when i try to use web dialer it show me an error " Failed to open device / line, and when  i associate a device (ephone) to the user the web dialer works very well.
is it extension mobility using only device profile supported for web dialer?
Jose Luis Arango Carvajal
1 REPLY
Re: Web dialer with Extension Mobility
Jose,
From: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/cmapps.html#wp1044551
WebDialer Interactions with EM
WebDialer users can log in to their phones using EM. EM users wishing to  use WebDialer simply need to select the Use Extension Mobility setting under the Cisco WebDialer Preferences page.
Check the EM seeting for WebDialer and see if that helps.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
506
