webex connect with ccme
hi
i am trying to integrate webex connect with ccme.i have intalled connectcmeplugin.but i need the webex connect software and username and password for webex connect.where can i find these?
thanks
kavi
Everyone's tags (4)
Blue
HI
See if below link helps
http://www.webex.com/webexconnect/orgadmin/help/index.htm
regards
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Kavi,
You will need to purchase services from WebEx for this. Once purchased the services, you will be provided with login credentials to be used here & I guess they should be able to provide the WebEx Connect software client as well.
You need WebEx Connect 7.2 & later to avail calling functionality through WebEx connect + CME.
GP.
Pls rate helpful posts !!
thanks for reply.
i hope  it will be helpful
380
