Bronze
Weird Option 2 difference on Unity failover system
On our Primary Unity server, when you hit 2, it says "Enter the extension". However, on our Failover Unity server, when you hit 2 it says "Spell the name or distribution list".
Is this normal, or did the configs get out of sync somewhere? Both are running 4.0(5) with TSP 8.1(3).
1 ACCEPTED SOLUTION
Re: Weird Option 2 difference on Unity failover system
Unfortunately, not everything in the SA is in the DB. Some of it is still written out to the registry where it does not get replicated. The Dialing Domain settings are a good example of this. From the Advanced Settings Tool, it looks like the setting you are interested in uses this registry key:
\Software\Active Voice\Conversations\1.0\Subscriber Send
-Eric
Silver
The first place I would look is in the SA Configuration\settings page:
Address messages to other subscribers:
Enable spelled name search
Make sure the setting is the same on both servers. Hope this it.
rlp
Bronze
Indeed, the settings are different. I'm just confused as to why, because I thought the failover pulled all settings from the primary via SQL replication. Hmmm.
Silver
Me too, hmm. Everything in the SA should be in a SQL table. I took a quick look but was not able to find that setting in a table.
I also found SQL replication errors in my unitydb on my failover server. :-(
rlp
Bronze
Are you seeing the following in the Primary's event viewer every 30 minutes by chance?
AvCsNodeMgr unable to connect to SQL Server on LocalHost. Error 0x80040000.
Silver
No, I think the conflict in the Unitydb might have happened at install of the failover server when we ran failoverconfig. It only happened once and everything is working now.
That is an interesting username you have.
-Eric
Ok, that's not the setting you are looking for but the point still stands that not everything entered in the SA gets replicated with the database.
I have come acros similar error ... in my case i do not see 'Subscriber Send' under regirtry config path
key:
\Software\Active Voice\Conversations\1.0\ ....  can you please guide me on what has to be done
350
