You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
2.0(3a) firmware upgrade
I'm trying to upgrade our UCS to 2.0(3a), but when I go to upgrade the IO Modules, the only option I see besides the current 2.0(1s) is 2.0(2q). Should I pick 2.0(2q) or should I see 2.0(3a) as an option?
--Carl
  • Unified Computing
Everyone's tags (3)
Re: 2.0(3a) firmware upgrade
You should see a 2.0(3a) option for the IOMs as well. Have you upgraded anything else, and if so did you see a 2.0(3a) option from the dropdown?
If you very recently uploaded the firmware bundle, it may take a couple of minutes to extract and verify the contents before the firmware will be available to update or activate.
Yes, I see 2.0(3a) available for everything else. I've had the firmware bundle for a couple of weeks now.
--Carl
You might try re-uploading the bundle. I'm guessing the IOM firmware failed an integrity check and was discarded.
Go to equipment - firmware management - download tasks - Make sure the FSM status for the download is "nop".
other the "nop", it does mean that the download did not occur successfully.
thank you,
AK G
987
