6200 FCoE Northbound
dbartlett
I have a quick question that I've not been able to get a definitive  answer to (in the documentation) - in relation to the new 6200 FI's and  FCoE northbound..
Anyway, my question: With the UP feature on the 6200's  (with UCS 2.0) - can we now do FCoE northbound (in this case to a nexus  5548UP)? Or do we still need to break out into separate eth and FC  uplinks?
I see from the config guide we can configure ports as  FCoE ports - and the options for eth Uplinks and FC uplinks are still  there also. I have not been able to determine if the FCoE port type can  be used for uplinks.
Thanks in advance!!
abbharga
Level 4
Level 4
Hi Daniel,
* You still cannot do northbound FCoE connectivity from the UCS FI i.e. in your case you cannot have FCoE uplink between 62xx and the 5548UP.
* You still need to have seprate FC uplinks and Eth uplinks.
* The feature of having FCoE uplink will be avaiable in a future release (scheduled around the year end).
* the FCoE ports you see are for use when you want to direct attch a FCoE storage to the FI (limited support model).
Hope this helps!
./Abhinav
abbharga
Level 4
Level 4
Hi Daniel,
Hope this helps!
./Abhinav
Nice one - thanks for the response.
