07-22-2012 05:33 AM - edited 03-01-2019 10:31 AM
I have read conflicting information regarding both Ethernet and native FC uplinks to the same Nexus 5548 switches – I am looking for clarification if this is supported or not?
Secondly, when can we expect support for FCoE from the 6200 north to 5548UPs?
Solved! Go to Solution.
07-22-2012 05:40 AM
Hi Nael,
You can certainly have the eth and fc links going to the same uplink N5k, however you will have to make sure the N5K is running the NPIV feature for FC (i just mentioned this in one of the post on the CSC a few days back).
As for the FCoE uplink it should be avaiable later this year, probably by the end of the year.
./Abhinav
07-22-2012 05:40 AM
Hi Nael,
./Abhinav
07-23-2012 05:34 AM
Thanks for the quick response
