Abort "decommission process" for a non present device
Hello Ladies, Gents,
I've a very stupid issue and I don't know how to go on. So may be you've some additional ideas.
I joined a project where UCS is the plattform for the core business. Unfortunately the last service provide who was responsible for the system had a knowledge lack by administrating a UCS.
The stupid situation is, that there is a chassis shown in UCSM with ID 3, which dosen't physically exist. As far as I know they tried to add a chassis, plugged everything in and plugged it out because the chassis was needed somewhere else. The current status of Chassis 3 is: decommissioning... with communication error - so it hangs. Unfortunately I can't stop that process - cause I don't know how.
After stoping the process I'd like to use the Remove link to delete the chassis from the configuration.
It's absolutly crazy but it is a high critical business critical environment where I can't go on with "erase and reconfigure"
I hope some of you have an idea.
Please keep me up to date.
Everyone's tags (4)
VIP Green
Hallo SaschaGuidelines for
Hallo Sascha
Guidelines for Removing and Decommissioning Chassis
Decommissioning a Chassis
Decommissioning is performed when a chassis is physically present and connected but you want to temporarily remove it from the configuration. Because it is expected that a decommissioned chassis will be eventually recommissioned, a portion of the chassis' information is retained by Cisco UCS Manager for future use.
Removing a Chassis
Removing is performed when you physically remove a chassis from the system. Once the physical removal of the chassis is completed, the configuration for that chassis can be removed in Cisco UCS Manager. You cannot remove a chassis from Cisco UCS Manager if it is physically present and connected. If you need to add a removed chassis back to the configuration, it must be reconnected and then rediscovered. During rediscovery Cisco UCS Manager will assign the chassis a new ID that may be different from ID that it held before.
I would try to remove the chassis; of this doesn't work, please open a TAC case !
Walter.
Thanks for your fast response
Thanks for your fast response!!
Than I have to open a TAC case. The problem is that the "Remove" link is greyed out because of the "running and hang" decommission process.
Sascha
VIP Green
Hallo SaschaMeanwhile I found
Hallo Sascha
Meanwhile I found this (not exactly your case !)
http://www.kozeniauskas.com/itblog/2013/12/27/ucs-chassis-decommission-is-stuck/
therefore my question: are the ports on the fabric interconnect connecting this chassis still configured as "server" ports ?
If yes, I would unconfigure them and see what happens ?
Walter.
214
