Community Member
B series hosts connected to MDS and SAN not showing up
OK so I just installed a B series chassis with two 6248 FI's connected to two seperate MDS 9124 FC switches.  The MDS switches have been in production for a while and have our SAN as well as other hosts connected to them.  My SAN is setup in passive mode and basically just discoveres all devices connected to the FC switches that are in the same zone.  THe problem I am having is my SAN can see all my blades that are connected to MDS-A but none of them that are connected to MDS-B.   The SAN can see other hosts connected to MDS-B just fine.  I had my cisco guys in here yesterday looking at the config for hours and they say it should be working.  We are at a loss and Im hoping someone here can take a look at the two below configs and point out something we are doing wrong.  In the configs you will notice the new hosts are labeleld
In the MDS-A config the new hosts are labeled the following and are seen perfectly by the san.  They have the same basic naming conventions on MDS-B
[ESX5-P2]
[ESX6-P2]
[ESX7-P2]
[ESX8-P2]
[UCS-FI-A]
[UCS-FI-A2]
Can someone please help?
--------------------------------------------------------MDS-A Config-------------------------------------------------------------------
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2009, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
MDS-1# show run
version 4.1(3a)
feature npiv
feature telnet
role name default-role
  description This is a system defined role and applies to all users.
  rule 5 permit show feature environment
  rule 4 permit show feature hardware
  rule 3 permit show feature module
  rule 2 permit show feature snmp
  rule 1 permit show feature system
no password strength-check
ip domain-lookup
ip host MDS-1 10.26.x.x
aaa group server radius radius
priv 0x5e7b72de1e7ec5ce6d94f543f2d67d49 localizedkey
snmp-server enable traps fcs
snmp-server enable traps fcns
snmp-server enable traps fdmi
snmp-server enable traps fspf
snmp-server enable traps rscn
snmp-server enable traps zone
snmp-server enable traps callhome
snmp-server enable traps fcdomain
snmp-server enable traps fcns db-full
snmp-server enable traps fcns reject-reg-req
snmp-server enable traps fcns local-entry-change
snmp-server enable traps aaa server-state-change
snmp-server enable traps fcns remote-entry-change
snmp-server enable traps vrrp
snmp-server enable traps snmp authentication
snmp-server community sptftech group network-operator
vsan database
  vsan 100 name "Primary-SAN"
device-alias database
  device-alias name CU0-FC0 pwwn 21:00:00:0b:08:04:4d:c0
  device-alias name CU1-FC0 pwwn 22:00:00:0b:08:04:4d:c0
  device-alias name ESX1-P1 pwwn 21:00:00:1b:32:9f:ab:64
  device-alias name ESX2-P1 pwwn 21:00:00:1b:32:9d:9a:4c
  device-alias name ESX3-P1 pwwn 21:00:00:24:ff:31:50:ca
  device-alias name ESX4-P1 pwwn 21:00:00:24:ff:24:80:68
  device-alias name ESX5-P2 pwwn 20:00:00:25:b5:01:a0:6f
  device-alias name ESX6-P2 pwwn 20:00:00:25:b5:01:a0:7f
  device-alias name ESX7-P2 pwwn 20:00:00:25:b5:01:a0:4f
  device-alias name ESX8-P2 pwwn 20:00:00:25:b5:01:a0:5f
  device-alias name UCS-FI-A pwwn 20:20:54:7f:ee:ad:32:00
  device-alias name UCS-FI-A2 pwwn 20:1f:54:7f:ee:ad:32:00
device-alias commit
fcdomain fcid database
  vsan 100 wwn 21:00:00:0b:08:04:4d:c0 fcid 0x5a0000 dynamic
!              [CU0-FC0]
  vsan 100 wwn 22:00:00:0b:08:04:4d:c0 fcid 0x5a0100 dynamic
!              [CU1-FC0]
  vsan 100 wwn 21:00:00:1b:32:9f:ab:64 fcid 0x5a0200 dynamic
!              [ESX1-P1]
  vsan 100 wwn 21:00:00:1b:32:9d:9a:4c fcid 0x5a0300 dynamic
!              [ESX2-P1]
  vsan 100 wwn 21:00:00:24:ff:24:80:68 fcid 0x5a0400 dynamic
!              [ESX4-P1]
  vsan 1 wwn 20:20:54:7f:ee:a6:c6:40 fcid 0x260000 dynamic
  vsan 100 wwn 20:20:54:7f:ee:a6:c6:40 fcid 0x5a0500 dynamic
  vsan 100 wwn 21:00:00:24:ff:31:50:ca fcid 0x5a0700 dynamic
!              [ESX3-P1]
  vsan 100 wwn 20:20:54:7f:ee:ad:32:00 fcid 0x5a0600 dynamic
!              [UCS-FI-A]
  vsan 100 wwn 20:00:00:25:b5:01:a0:5f fcid 0x5a0601 dynamic
!              [ESX8-P2]
  vsan 100 wwn 20:00:00:25:b5:01:a0:4f fcid 0x5a0802 dynamic
!              [ESX7-P2]
  vsan 100 wwn 20:00:00:25:b5:01:a0:7f fcid 0x5a0604 dynamic
!              [ESX6-P2]
  vsan 100 wwn 20:00:00:25:b5:01:a0:6f fcid 0x5a0801 dynamic
!              [ESX5-P2]
  vsan 100 wwn 20:1f:54:7f:ee:ad:32:00 fcid 0x5a0800 dynamic
!              [UCS-FI-A2]
vsan database
  vsan 100 interface fc1/1
  vsan 100 interface fc1/2
  vsan 100 interface fc1/3
  vsan 100 interface fc1/4
  vsan 100 interface fc1/5
  vsan 100 interface fc1/6
  vsan 100 interface fc1/7
  vsan 100 interface fc1/8
  vsan 100 interface fc1/9
ip default-gateway 10.26.19.1
switchname MDS-1
line console
boot kickstart bootflash:/m9100-s2ek9-kickstart-mz.4.1.3a.bin
boot system bootflash:/m9100-s2ek9-mz.4.1.3a.bin
interface fc1/1
interface fc1/2
interface fc1/3
interface fc1/4
interface fc1/5
interface fc1/6
interface fc1/7
interface fc1/8
interface fc1/9
interface fc1/10
interface fc1/11
interface fc1/12
interface fc1/13
interface fc1/14
interface fc1/15
interface fc1/16
interface fc1/17
interface fc1/18
interface fc1/19
interface fc1/20
interface fc1/21
interface fc1/22
interface fc1/23
interface fc1/24
!Full Zone Database Section for vsan 100
zone name shared-zone vsan 100
    member pwwn 21:00:00:1b:32:9f:ab:64
!               [ESX1-P1]
    member pwwn 21:00:00:1b:32:9d:9a:4c
!               [ESX2-P1]
    member pwwn 21:00:00:0b:08:04:4d:c0
!               [CU0-FC0]
    member pwwn 22:00:00:0b:08:04:4d:c0
!               [CU1-FC0]
    member pwwn 21:00:00:24:ff:31:50:ca
!               [ESX3-P1]
    member pwwn 20:00:00:25:b5:01:a0:6f
!               [ESX5-P2]
    member pwwn 21:00:00:24:ff:24:80:68
!               [ESX4-P1]
    member pwwn 20:00:00:25:b5:01:a0:7f
!               [ESX6-P2]
    member pwwn 20:00:00:25:b5:01:a0:4f
!               [ESX7-P2]
    member pwwn 20:00:00:25:b5:01:a0:5f
!               [ESX8-P2]
    member pwwn 20:20:54:7f:ee:ad:32:00
!               [UCS-FI-A]
    member pwwn 20:1f:54:7f:ee:ad:32:00
!               [UCS-FI-A2]
zoneset name shared-zoneset vsan 100
    member shared-zone
zoneset activate name shared-zoneset vsan 100
interface fc1/1
  switchport description CU1-FC0
  port-license acquire
  no shutdown
interface fc1/2
  switchport description ESX4-P1
  no shutdown
interface fc1/3
  switchport description CU0-FC0
  no shutdown
interface fc1/4
  switchport description ESX3-P1
  no shutdown
interface fc1/5
  switchport description ESX1-P1
  no shutdown
interface fc1/6
  switchport description UCS Fabric Interconnect A
  no shutdown
interface fc1/7
  switchport description ESX2-P1
  no shutdown
interface fc1/8
  no shutdown
interface fc1/9
interface fc1/10
interface fc1/11
interface fc1/12
interface fc1/13
interface fc1/14
interface fc1/15
interface fc1/16
interface fc1/17
interface fc1/18
interface fc1/19
interface fc1/20
interface fc1/21
interface fc1/22
interface fc1/23
interface fc1/24
interface mgmt0
  ip address 10.26.x.x 255.255.255.0
----------------------------------------------------------------------MDS-B (Not showing hosts on SAN) config------------------------------------------------------
MDS-2# show run
version 4.1(3a)
feature npiv
feature telnet
ip domain-lookup
ip host MDS-2 10.26.x.x
priv 0x6e724287d3740ca7542d6c1f412dad4d localizedkey
vsan database
  device-alias name CU0-FC1 pwwn 23:00:00:0b:08:04:4d:c0
  device-alias name CU1-FC1 pwwn 24:00:00:0b:08:04:4d:c0
  device-alias name ESX1-P2 pwwn 21:01:00:1b:32:bf:ab:64
  device-alias name ESX2-P2 pwwn 21:01:00:1b:32:bd:9a:4c
  device-alias name ESX3-P2 pwwn 21:00:00:24:ff:31:50:cb
  device-alias name ESX4-P2 pwwn 21:00:00:24:ff:24:80:69
  device-alias name ESX5-P2 pwwn 20:00:00:25:b5:01:b0:6f
  device-alias name ESX6-P2 pwwn 20:00:00:25:b5:01:b0:7f
  device-alias name ESX7-P2 pwwn 20:00:00:25:b5:01:b0:4f
  device-alias name ESX8-P2 pwwn 20:00:00:25:b5:01:b0:5f
  device-alias name UCS-FI-B pwwn 20:20:54:7f:ee:a6:c6:40
  device-alias name UCS-FI-B2 pwwn 20:1f:54:7f:ee:a6:c6:40
device-alias commit
  vsan 100 wwn 23:00:00:0b:08:04:4d:c0 fcid 0x710000 dynamic
!              [CU0-FC1]
  vsan 100 wwn 24:00:00:0b:08:04:4d:c0 fcid 0x710100 dynamic
!              [CU1-FC1]
  vsan 100 wwn 21:01:00:1b:32:bf:ab:64 fcid 0x710200 dynamic
!              [ESX1-P2]
  vsan 100 wwn 21:01:00:1b:32:bd:9a:4c fcid 0x710300 dynamic
!              [ESX2-P2]
  vsan 100 wwn 21:00:00:24:ff:31:50:cb fcid 0x710400 dynamic
!              [ESX3-P2]
  vsan 100 wwn 21:00:00:24:ff:24:80:69 fcid 0x710500 dynamic
!              [ESX4-P2]
  vsan 100 wwn 20:00:00:25:b5:01:b0:7f fcid 0x710708 dynamic
!              [ESX6-P2]
  vsan 100 wwn 20:20:54:7f:ee:a6:c6:40 fcid 0x710600 dynamic
!              [UCS-FI-B]
  vsan 100 wwn 20:00:00:25:b5:01:b0:5f fcid 0x710601 dynamic
!              [ESX8-P2]
  vsan 100 wwn 20:00:00:25:b5:01:b0:4f fcid 0x710704 dynamic
!              [ESX7-P2]
  vsan 100 wwn 20:00:00:25:b5:01:b0:6f fcid 0x710701 dynamic
!              [ESX5-P2]
  vsan 100 wwn 20:1f:54:7f:ee:a6:c6:40 fcid 0x710700 dynamic
!              [UCS-FI-B2]
vsan database
ip default-gateway 10.26.x.x
switchname MDS-2
line console
interface fc1/6
  switchport rate-mode dedicated
interface fc1/8
interface fc1/1
interface fc1/2
interface fc1/3
interface fc1/4
interface fc1/5
interface fc1/7
interface fc1/9
interface fc1/10
interface fc1/11
interface fc1/12
interface fc1/13
interface fc1/14
interface fc1/15
interface fc1/16
interface fc1/17
interface fc1/18
interface fc1/19
interface fc1/20
interface fc1/21
interface fc1/22
interface fc1/23
interface fc1/24
interface fc1/6
interface fc1/8
    member pwwn 23:00:00:0b:08:04:4d:c0
!               [CU0-FC1]
    member pwwn 24:00:00:0b:08:04:4d:c0
!               [CU1-FC1]
    member pwwn 21:01:00:1b:32:bf:ab:64
!               [ESX1-P2]
    member pwwn 21:01:00:1b:32:bd:9a:4c
!               [ESX2-P2]
    member pwwn 21:00:00:24:ff:24:80:69
!               [ESX4-P2]
    member pwwn 21:00:00:24:ff:31:50:cb
!               [ESX3-P2]
    member pwwn 20:20:54:7f:ee:a6:c6:40
!               [UCS-FI-B]
    member pwwn 20:1f:54:7f:ee:a6:c6:40
!               [UCS-FI-B2]
    member shared-zone
interface fc1/1
  switchport description CU1-FC1
  no shutdown
interface fc1/2
  switchport description ESX4-P2
  no shutdown
interface fc1/3
  switchport description CU0-FC1
  no shutdown
interface fc1/4
  switchport description ESX3-P2
  no shutdown
interface fc1/5
  switchport description ESX1-P2
  no shutdown
interface fc1/6
  no shutdown
interface fc1/7
  switchport description ESX2-P2
  no shutdown
interface fc1/8
  no shutdown
interface fc1/9
interface fc1/10
interface fc1/11
interface fc1/12
interface fc1/13
interface fc1/14
interface fc1/15
interface fc1/16
interface fc1/17
interface fc1/18
interface fc1/19
interface fc1/20
interface fc1/21
interface fc1/22
interface fc1/23
interface fc1/24
interface mgmt0
Community Member
Few things to check,
1. Check that the port on FI-B that connects to MDS-B is configured to use VSAN 100 and that the port is up.
2. Check the service profiles for the ESX servers in UCS have a vHBA configured to use fabric B.
Community Member
Make sure that NPIV is enabled on the MDS-B switch ports which are connected with FI. Also please provide the output for command #show flogi database.
Also on MDS-B try out the commands fcping "wwpn of blade" "wwpn of storage port".
Community Member
Re: B series hosts connected to MDS and SAN not showing up
So it looks like npiv is enabled, 'feature npiv'.
I see the VSAN is the same across both switches, unconventional but workable. Is the VSAN configured on all of the uplink ports of the UCS FI's (typically as a dual fabric VSAN) - there are two steps here; 1. configure VSAN across the UCS, 2. Configure each of the uplink ports with the necessary VSAN.
Is the HBA configuration failover or dual? In a similar fashion to vNIC failover, you might not see the addresses log into the Fabric in this configuration.
Ideally, each FI has it's own MDS, each with it's own VSAN. The MDS' are meshed back to the SAN's. I can confirm that this configuration works with UCS 6120XP each uplinked to a dedicated MDS9148 which are in turned meshed to EMC VNX 5500 SAN, EMC VNX5700 SAN and Storagetek 6540 SAN.
Community Member
Also, while I think of it, NXOS 4.x is relatively old.Our MDS9148's, which are just over 12 months old, shipped with 5.0.1a. They all got upgraded to 5.2.2d in August this year.
It would be worth checking the NXOS code version VS UCS code revision VS SAN code VS OS/Hypervisor as well.
Community Member
the weirdest thing is
there is also a command
npiv enable
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/nx-os/command/reference/CR04_n_ps5989_TSD_Products_Command_Reference_Chapter.html#wp1275749
If i remember correctly you need that one as well besides the feature npiv
943
