VIP Red
B22-M3 and Boot from SAN with W2008 R2 SP1
I have a rather weired situation.
Service profile with boot from SAN
Associate with a B22-M3
Boot lun visible
Installing W2008 R2 SP1 on a boot lun (HDS storage) works perfekt
However, boot fails ! we see Windows starting, and then it starts loop, booting again and again
Associating this same Service Profile to a B200-M3 works, Boot from SAN is ok
Has this been seen ?
1 ACCEPTED SOLUTION
Hey Wdey,
I just wanted to let you know that someone I worked with was running into the same issue and we found that what the problems problmes was related to the defect below.
Installation of windows 2008 R2 fails on UCS 2.1.3a BIOS
https://tools.cisco.com/bugsearch/bug/CSCum84618
Walter,
Which adapters are you using in the B22 and B200?
Robert
VIP Red
Hi Robert
B22-M3 has a MLOM, B200-M3 has MLOM and VIC-1280
I have seen some issue, which could explain the issue: the memory Dimm's in the B22-M3 are not properly configured ! I have to investigate further and let you know.
Btw. I forgot to mention, that for the B22-M3, Windows actually blue screens, upon booting from the lun.
Cheers
Walter.
Yeah that BSOD could be a problem.  I'd also remove the VIC 1280 from the B200 to ensure the VIFs aren't being instantiated on it.  Compare Apples:Apples this way.
Looking forward to your update once the memory issue is sorted.
Rob
Hi Wdey,
Is the firmware on both the B22 and the B200 server the same? If not lets make sure that the servers are running the correct firmware.
Thank you
VIP Red
Hi Manuel
UCS domain run's at 2.1.3a
Firmware on both blades are at 2.1.3a as well
Walter.
VIP Red
I found the following Dimm alloaction on the B22-M3 32 GB configuration
Equipped Product Name: Cisco UCS B22 M3
    Equipped PID: UCSB-B22-M3
    Equipped VID: V01
    Equipped Serial (SN): FCH163274X9
    Slot Status: Equipped
    Acknowledged Product Name: Cisco UCS B22 M3
    Acknowledged PID: UCSB-B22-M3
    Acknowledged VID: V01
    Acknowledged Serial (SN): FCH163274X9
    Acknowledged Memory (MB): 32768
    Acknowledged Effective Memory (MB): 32768
    Acknowledged Cores: 4
    Acknowledged Adapters: 1
    Bios:
        Model: UCSB-B22-M3
        Revision: 0
        Serial:
        Vendor: Cisco Systems, Inc.
    Motherboard:
        PID: UCSB-B22-M3
        VID: V01
        Vendor: Cisco Systems Inc
        HW Revision: 0
        Array 1:
            DIMM Location   Presence         Overall Status           Type         Capacity (MB) Clock
               1 B0         Equipped         Operable                 Ddr3         16384         1600
               2 B1         Missing          Removed                  Undisc       Unknown       Unknown
               3 C0         Equipped         Operable                 Ddr3         16384         1600
               4 C1         Missing          Removed                  Undisc       Unknown       Unknown
               5 D0         Missing          Removed                  Undisc       Unknown       Unknown
               6 D1         Missing          Removed                  Undisc       Unknown       Unknown
               7 F0         Missing          Removed                  Undisc       Unknown       Unknown
        CPUs:
            Presence: Equipped
            Architecture: Xeon
            Socket: CPU1
            Cores: 4
            Speed (GHz): 1.800000
            Stepping: 7
            Product Name: Intel(R) Xeon(R) E5-2403
            PID: UCS-CPU-E5-2403
            VID: 01
            Vendor: Intel(R) Corporation
            HW Revision: 0
            Presence: Missing
            Architecture: Unknown
            Socket:
            Cores: Unspecified
            Speed (GHz): Unspecified
            Stepping: Unspecified
            Product Name:
            PID:
            VID:
            Vendor:
            HW Revision: 0
Is this correct ?
Re: B22-M3 and Boot from SAN with W2008 R2 SP1
That does not seem right...
If he wants 32 GB of memory, he needs to configured it like:
B0  B1   C0   C1   D0   D1
4     4      4     4      8       8     <<<< DIMMs size
What he can do is to move the 16GB DIMMs and move them to D0-D1 and buy 4x 4GB to install them in B0-1/ & C0-1 to have 48GB DIMMs and take advantage of the DIMMs he already has
-Kenny
VIP Red
Thanks Keny ! This configuration is also running at 1600 Mhz (if Dimms and CPU support 1600 Mhz) ?
I have yet another question, of a 2 CPU, 8 x 16G Dimm (128GB) B22-M3, where discovery fails ! could this also be a memory configuration misconfiguration ?
Server 2/5:
    Equipped VID: V01
    Equipped Serial (SN): FCH16387E48
    Acknowledged Serial (SN): FCH16387E48
    Acknowledged Memory (MB): 131072
    Acknowledged Effective Memory (MB): 131072
    Acknowledged Cores: 12
    Bios:
        Model: UCSB-B22-M3
        Revision: 0
        Serial:
    Motherboard:
        PID: UCSB-B22-M3
        VID: V01
        HW Revision: 0
        Array 1:
               2 B1         Equipped         Operable                 Ddr3         16384         1600
               5 D0         Equipped         Operable                 Ddr3         16384         1600
               7 F0         Equipped         Operable                 Ddr3         16384         1600
               8 F1         Equipped         Operable                 Ddr3         16384         1600
               9 G0         Equipped         Operable                 Ddr3         16384         1600
              10 G1         Missing          Removed                  Undisc       Unknown       Unknown
              11 H0         Equipped         Operable                 Ddr3         16384         1600
              12 H1         Missing          Removed                  Undisc       Unknown       Unknown
        CPUs:
            Presence: Equipped
            Architecture: Xeon
            Socket: CPU1
            Cores: 6
            Speed (GHz): 1.900000
            Stepping: 7
            Product Name: Intel(R) Xeon(R) E5-2420
            PID: UCS-CPU-E5-2420
            VID: 01
            HW Revision: 0
            Presence: Equipped
            Architecture: Xeon
            Socket: CPU2
            Cores: 6
            Stepping: 7
            VID: 01
            HW Revision: 0
VIP Red
According to the installation guide for B22-M3
B0, C0, D0, B1
F0, G0, H0, F1
Above should be ok and run at 1600 Mhz ! please confirm ?
VIP Red
Keny, now I'm really confused.
If you look at the installation guide of B22-M3, table 2, http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/blade-servers/B22.pdf, it says B0, C0 !! which contradicts, whats in the B22-M3 Spec
Table 2: Preferred DIMM Population Order
DIMMs per CPU CPU 1 installed slots CPU 2 installed slots
1 B0 F0
2 B0, C0 F0, G0 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
3 B0, C0, D0 F0, G0, H0
4 B0, C0, D0, B1 F0, G0, H0, F1
5 B0, C0, D0, B1, C1 F0, G0, H0, F1, G1
6 B0, C0, D0, B1, C1, D1 F0, G0, H0, F1, G1, H1
Walter,
I think the confusion here is the fact that both (the spec sheet and the installation guide) talk about either 1 DIMM per channel OR 2 DIMMs per channel.  Your customer is doing both at the same time  {EDIT: I am not saying that is wrong, I am saying that is the confusion you see when looking at both documents}
-Kenny
VIP Red
Hi Kenny et al
Just to summarize the inital problem, again, and highlight the discrepancy in different Cisco documents.
Customer ordered B22-M3 with one CPU and 2 x 16 G Dimm.
He then opens the blade, and compares the shipped configuration, which I assume is done like in the B22-M3 spec
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/b22m3_specsheet.pdf
Table 24 , namely D0, D1 (as Kenny said above)
customer then checks http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/blade-servers/B22.html
Table 2, which says B0, C0
And changes B0, C0 to D0, D1, which might be wrong !!!!
Thanks for any clarification ! it's urgent
Thanks Walter.
Walter,
How much memory did your customer wanted to have installed in the server (as a total and not per CPU) ?
-Kenny
VIP Red
B22-M3 with one CPU and 32 GB; with 16Gb Dimm's
Walter,
Ok, so I understand he wanted 32GB in the server, with only 2 DIMMs in CPU1
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/b22m3_specsheet.pdf Table 24  <<< This only applies if you are mixing 4GB DIMMs with 8 GB or 16 GB DIMMs, since there is no mix in the server, that table does not apply.
Then, as I mentioned above, if he wants 32 GB of memory, he needs to configured as shown below and that involves mixing 4&8GB DIMMs:
B0  B1   C0   C1   D0   D1
Now, since he is not doing a mix, he has 2 options:
1- If he uses the 1DPC option, he may provision the server with 24, 48 OR 96GB total  (other options have not gone through QA, reason why other options are not documented. Does not mean it does not work, it means it was not fully tested)
2-If he wants to use only 2 DIMMs (which is different to 1DPC & 2DPC options) he can install DIMMs in Slots B0&C0, as per     Table 2 in http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/blade-servers/B22.html    <<<<< So, I was initially wrong cause I ignored this "Table 2", please excuse me
{EDIT} I will look to see if table 2 (from http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/blade-servers/B22.html )   can be included in
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/b22m3_specsheet.pdf to avoid anyone else ignoring one or the other.
-Kenny
VIP Red
Thanks Kenny
If you read above, this is what the customer actually has, 2 x 16G Dimm's in B0, C0
This means the blue screen during the boot from san problem is still not resolved.
Walter.
VIP Red
Or a more basic question: is a 32 GB memory configuration for B22-M3 and one CPU supported ? I only see the smallest configuration starting at 48 GB.
VIP Red
Btw. this 32 GB Memory configuration ( 2 x 16G Dimms) is running at 1000 Mhz !!!! is this ok ????
Processor is Xeon(R) E5-2403, Memory Dimms are 1600 Mhz capable
Walter,
If you have not, please open a TAC case if you dont mind and ask for the confirmation in regards to the correction/confirmation about the docs discussed, it is complicated without the case number for me.   You may open the case with the keyword "Product Questions and Features"
-Kenny
Hi Wdey,
About this post, do you remember what you did to resolve this issue?
VIP Red
Hi Manuel
Very strange indeed !
customer did erase the whole UCS domain, and started after a power cycle from scratch (initially this was only a PoC); and then the whole problem disappeared.
I think, too many changes have been done, without actually doing disassoc / associate the SP; this might be one of the problems.
It is strange, and it doesn't make sense.
Hey Wdey,
VIP Red
Thanks Manuel ! Good to know ! is this fixed with 2.2.1b/c ?
Hi Wdey,
This defect is not fixed yet, but I haven’t seen anyone running into this problem on the 2.2 release.
957
