B440 M2 Memory in a B200 M2
I have some extra memory in a B440 M2 that I would like to reuse in another blade.  Other than the B440 M2s, I have B200 M2s and B230 M2s.  Can I use B440 M2 memory in either of these blades??
John
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hi Jonh,
Yes you can use all of the extra DIMM on the B230 M2 except for the 32GB one. (see screenshots and compare DIMM PIDS).
Just remember that these come in pairs and you want to keep te pairs together.  Also when installing the dimms make sure to follow the dimm population guidelines found on the spec sheet below.
B200 M2 Available DIMMS (page 11)
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/spec_sheet_c17-644236.pdf
B230 M2 Available DIMMS (page 10)
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/b230m2_specsheet.pdf
B440 M2  Available Memory (page 11)
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/spec_sheet_c17_662218.pdf
Hi Jonh,
Thank you for the information, this was exactly what I was looking for.
Re: B440 M2 Memory in a B200 M2
Hi John
Did you find the information you were looking for?
Be kind and Mark as Answer if I helped.
370
