B440M2 on UCS 1.4.3s
hi team,
in the latest UCS hardware and software interoperability matrix, we can see 1.4.3 begin to support vmware version 5 as well.
But in the interoperability matrix, vmware vsphere 5 is only support on B440M1.
Does Cisco has any plan to support vmware vsphere 5 on B440M2?
1 ACCEPTED SOLUTION
Tentative schedule is Mar / April 2012. But I would highly suggest you to consult your Cisco sales team / check the HCL before deploying it.
Padma
Hello David,
I will get back to you on ESXi 5.0 support on B440 M2 with UCSM 1.4.3s
Padma
Hi Padma,
Thank you very much!!!
David,
HCL is correct that we do not currently support B440 M2 with ESXi 5.0 & UCSM 1.4.3s version.
As of now, we have plans to support it down the line but do not have an ETA for it's qualification.
Padma
Re: B440M2 on UCS 1.4.3s
Hi Padma,
Does Cisco has any timeline for UCS 1.4.3x to support B440M2?
Best Regards,
Padma
707
