Behavior of UCSM vNIC/vHBA placement policy
tprayaga
Level 4
Level 4
hi,
Can anyone please explain me the behavior of UCSM vNIC/vHBA placement policy, and its three options assigned-only, Exclude-Dynamic and Exclude-Unassigned. I have gone through the documentation, but I am not very clear yet.
May be an explaining with an example will help.
Sample scenario.
Full blade having Palo on left side, and Menlo Emulex on right side, with 8 VNICs (4 dynamic, and 4 manual), with each of the three options.
thanks
Tejo
Jeremy Waldrop
Level 4
Level 4
Tejo, there are two reasons that you would want to use a placement policy.
  1. Full width blades with 2 mezzanine cards - When you have 2 mezzanine cards a placement policy      allows you to specify which mezzanine card to assign a vNIC/vHBA to. By      doing this you can better load balance the network and storage traffic. In      a placement policy the 2 mezzanine cards are identified as vCon1 and      vCon2.
  2. Dynamic vNIC Connection Policy – When you have a Dynamic vNIC Connection Policy as      part of a Service Profile you want to have a placement policy so that the      dynamic vNICs are created below the standard vNIC/vHBAs in the PCI order.      Dynamic vNIC connection policies are used in the configuration of VN-Link      in hardware. This type of policy requires the Palo mezzanine card though.
Other than those two reasons I don't know when you would use a placement policy unless you just wanted to make sure the OS sees the vNICs/vHBAs on specific PCI slots.
The exclude-dynamic comes into play with the Dyamic vNIC Connection Policies I mentioned in option 2 above. Exclude-unassigned would be where you have some that you want to assign (vNICs) but you don not care about where the vHBAs get assigned.
I personally have only had the need to use them in the 2 scenarios above.
With your specific scenario you would use the placement policy to assign some vNICs/vHBAs to the Emulex card (2 max for vNIC and vHBAs) and some to the Palo (dynamic vNIC connection policy or more than 2 vNICs. Or you might want all of your vHBAs to use the Emulex and all of your vNICs to use the Palo.
Jeremy Waldrop
Level 4
Level 4
Thank you very much Jeremy for your detailed response. It makes a lot more sense now.
