C Series UCSM Integration Design
I have the following questions regarding the connectivity and integration with UCSM with the C220 M3.
The C220 M3 contains the following card UCSC-PCIE-CSC-02 (Cisco VIC 1225 Dual Port 10Gb SFP+ CNA) and UCSC-PCIE-ESFP (Emulex OCe11102-FX  Dual Port 10Gb SFP+ CNA)
1 - Is the card combination supported while integrating it with UCSM.
2- If we use the Single Wire Managment option, are the Mlom 2 x 1 GB port avaialble for connectivity to say a DMZ switch where the traffic doesnt flow through the FI's.
Derick
Everyone's tags (2)
Bronze
Re:C Series UCSM Integration Design
Derick,
Q1. Yes this card combination is suopported for UCSM integrated servers.
Q2. No. The PCIe complex for the LOMs are hidden to the system by the CIMC when in UCSM Integrated mode, even when you are in Single Wire mode.
Let me know if you need additional information.
Steve McQuerry
UCS - Technical Marketing
Sent from Cisco Technical Support Android App
What slot does the UCSC-PCIE
What slot does the UCSC-PCIE-ESFP card need to be installed in?  The Cisco documentation only has information pertaining to the VIC 1225 card.
240
