09-09-2014 11:56 AM - edited 03-01-2019 11:50 AM
We have a pair of C220 M3 servers that we have connected to a pair of fabrics (6248) for single-wire management through the VIC 1225. We'd like to also leverage the two on-board 1Gb NICs, however it is a bare metal Windows 2012 server and does not see the additional interfaces. The interfaces show up and connected to the downstream switch so we know they are enabled. However, the OS is not seeing the interfaces. We've run through the compat matrix for the drivers, but it is as though the interfaces are not being presented to the OS.
Just wanted to make sure there isn't something else with single-wire management that 'prevents' the OS on the server from using these interfaces?
Solved! Go to Solution.
09-10-2014 11:00 PM
Thats correct. I haven't tried that option by myself but that's something that can be tried would work.
Siva
09-10-2014 05:27 AM
refer doc below for supported cards with UCSM
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c-series_integration/ucsm2-0-2/b_UCSM_202_C-Integration/b_UCSM_202_C-Integration_chapter_011.html
The following are the only supported card combinations for the servers to be used in UCSM mode.
Siva
09-10-2014 06:52 AM
Thanks for the response and information, Siva. To confirm I'm reading that correctly, if you're using a VIC 1225 and single-wire management through UCSM you cannot also use the onboard 1Gb NICs, correct? We'll have to trunk to an upstream Nexus and pass through vNIC templates.
Thanks!
09-10-2014 11:00 PM
Siva
