C220M3 LSI Storaged Raid Subsystem not ready yet 9271-8i
New C220M3 with 9271-8i out of box with 2.0.1b firmware
Control H doesn't boot into WebBios, instead I get EFI Shell with map:cannot find required map name.
Press ESC in 1 seconds to skip startup.nsh, any other key to continue
From the CIMC I select 2 drives to create a drive group and it fails with message;
Error: Storage Raid subsystem not ready yet
See screenshot;
  • Unified Computing
1 ACCEPTED SOLUTION
Make sure the optionROM for
Make sure the optionROM for the raid controller is enable in the bios.
1)Reboot server
2)Press F2 when you see the option to go into bios
3)go to advance
4)select the last option here I believe it is LOM and PCIe
5) verify that in slot 2 the optionROM is loaded
1)Reboot server
3)go to advance
Thank you for provide this
Thank you for provide this solution. It fixed my issue. (BIOS not recognizing LSI RAID Controller)
By restarting CIMC it worked
By restarting CIMC it worked from me because above configuration is already in place as suggested.
2574
