01-10-2012 07:21 AM - edited 03-01-2019 10:13 AM
Is it possible to connect a 2248 downstream from a 6120 and have it act as a fex or is that not supported?
01-10-2012 07:25 AM
Not supported unless you're using the 2248 for UCS C-Series integration only.
It will not operate as a standalone FEX for any device to connect into.
Robert
01-10-2012 07:43 AM
Just to verify the FEXs can only connect to 5ks or 7ks.
ZyEdge
01-10-2012 07:48 AM
For purposes of connecting any 1G end networking devices to - Yes.
The same hardware (2248) just happens to be used for UCS C-Series integration, but this is strictly for Cisco Rack servers when used with the 6x00 Interconnects.
Regards,.
Robert
01-10-2012 08:03 AM
Robert,
The C460 M2 is not currently supported on the latest UCSM version. If you have 6120's with the 2248 to support the C-Series integration, can the C460 M2 be connected to this environment or will we need to wait until 2.0(2). Seems like a such a waste to devote 2248's to just LOM functions and not be able to do anything else with them.
-ryan
01-10-2012 08:35 AM
Ryan,
Completely valid points. The C460 (being a completely different architecture) will only be supported with UCS MR1 aka 2.0.(2). Also in this release we enter the next phase towards single-wire management. Previously with C-Series integration we required the 2248 for 1G LOM, and 10G data path uplinks (CNA) directly to the 6100's. In 2.0(2) we add support for the 2232 - in which both LOM and Datapath connect directly to. This in turn uplinks to the 6100's. This helps reduce the # of licensed FI ports required for C-Series integration for better scaling.
We understand it's not where it needs to be yet, but this phased approach gives the functionality while allowing us to develop & test single wire data+management. Muxing Management and the datapath over a single adapter is very complex. Unlike the B Series which has the out of band CIMC controller for management.
For what it's worth, the 2248's and 2232's can always be re-used as regular FEXs for N5K and N7K if you had these in your environment.
Robert
01-10-2012 11:04 AM
Thanks Robert, that clears up a lot. I understand 1H this year is the release date, do you think that means closer to June or do you expect the release date to be any earlier?
-ryan
01-10-2012 11:09 AM
We're tracking tentatively around the end of March, but I would expect the release to be sometime between early-mid April. High confidence it will be released well before June.
Robert
