Mal
Can I disable the B200 blade Fibre Channel vHBA's
Hello
I am configuring my service profiles for my B200 blades and was wondering if there was a way to disable the Fibre Channel HBA's. I will not be using FC as all my storage is iSCSI.
Mal
  • Unified Computing
1 ACCEPTED SOLUTION
VIP Red
When you create a service
When you create a service profile, you are asked if you want storage (=FC) or not; you say no !
if you missed this step, and you created vhba's, just delete them afterwards.
It is not possible to disable vhna's.
VIP Red
Mal
HiThanks for your replies.I
I am running version 2.1(3a), but will be upgrading it before it goes into production.
I was unable to delete the vHBA from the Service Profile or Service Profile Template, but when I created a new Service Profile Template and said NO to vHBS's, I no longer had an issue.
Many Thanks
Mal
Hi Mal, Disabling the
Hi Mal,
Disabling the individual interfaces is possible but only if you UCS environment is running the latest firmware version 2.2(3).
What firmware is your UCS running?
VIP Red
my comment:1) if he doesn't
my comment:
1) if he doesn't require FC, don't configure it in the service profile !
2) can you please give us a pointer, where disabling a vhba in 2.2.3 is documented. I checked
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/2-2/b_UCSM_GUI_Configuration_Guide_2_2/b_UCSM_GUI_Configuration_Guide_2_2_chapter_01.html
Table 3 New Features and Changed Behavior in Cisco UCS, Release 2.2(3)
and can't find it.
Hi Wdey,It looks like this
Hi Wdey,
It looks like this feature was added starting 2.2. I haven't had a chance to take a look at the documentation but you can take a look at the attached screenshot to see where you can disable the interfaces.
VIP Red
Thanks !Do you have an idea
Thanks !
Do you have an idea of the difference between
enable / enable - active / enable - passive
Enable - This will enable
Enable - This will enable both the active and passive hba in this case
Enable-Active - Will only enable the active hba
Enable-passive -  Will only enable the passive interface.
At this point I am not sure what is the difference between the active and passive, looks to me there is no difference.
78
