11-13-2013 08:03 AM - edited 03-01-2019 11:21 AM
We just got a new server wiith this controller, when try to configure it with the four (04) SAS drives to a Raid 10...OOHH no RAID 10 was able to choose.
I found a paper that says that the controller support RAID 10 :
Link:
Please anybody Should Know what happends.
Thanks.
William Z.
Solved! Go to Solution.
11-13-2013 09:35 AM
Hi William,
How are you configuring the raid volume? Are you using the WebBios utility?
If you are using the WebBios Utility you have to make sure that you create two spans of two disk each to be able to see raid 10 as an option. See the document below, it will show you how to configure raid 10 starting on page 76.
http://www.lsi.com/downloads/Public/MegaRAID%20Common%20Files/51530-00_RevF.pdf
11-13-2013 09:35 AM
Hi William,
11-15-2013 05:47 AM
William,
The document that Manuel shared is precisely the answer, you need to configure 2 groups of at least 2 disk each and then the option will appear.
Could you please mark Manuel's answer as the correct one so we can keep track of "non-answered" questions
Thanks in advance,
-Kenny
Cisco Support Community is also present in Spanish:
https://supportforums.cisco.com/community/spanish/data_center
11-18-2013 01:36 PM
Thanks Manuel / Keny for your help.
